hi all, hoping someone can put my mind at rest here. i did my body lift a while ago now and have just started to feel a knocking vibration through the steering wheel if i let the engine labour a bit.
turns out what was left of the rubber grommet in the bulkhead has disapeared so the steering shaft is knocking against the body.
i can get a good 3 or 4 mm play up and down on the shaft where it passes through the bulkhead, should i have any play there at all?
