Yeah,Done it.
Removed the plastic section and extended end caps from front bumper and only took me 30 mins,which is good for me!!!!!!
Straight forward enough, 6 bolts to get bumper off( 4 chassis,2 inside front of arch under arch liner) remember to take the indicator bulb fitting out the back. Then it's about 10 wee bolts. end caps can be pulled off as they slide into place on the bolt heads(if that makes sense
Cheers again for the pics Ian and the info from everyone else that guided me on my way. So when the Fiancee see's it i can blame you lot.hehe
My garage is now full of bits i've taken off my Surf.
)Cheers again for the pics Ian and the info from everyone else that guided me on my way. So when the Fiancee see's it i can blame you lot.hehe
