Running larger tyres??
  • Running larger tyres??
    This looks an interesting product for people running bigger than standard tyres.
    http://www.blackrobotics.com/yb_home.htm
    =SOLD UP!=
    I installed one on my truck a couple of months ago - it works brilliantly. Because it's got a wide range of adjustment you can check the speed against a gps and dial in the yellow box so the speedo is spot on. The only problem is I have to remember I'm not in the works Hilux whos speedo reads 10% fast (as standard)
    Roger
      May I ask where you located this? In the engine bay or under the dash?
      My speedo runs 6 mph slow so it might be worth getting on of these.
      Cheers, Paul
      Mine WAS a 150 bhp V6 and ran on PETROL
        Joined the wires to the instrument panel connector (there's only 3 wires) and just dropped the box in behind the lower dash.
        Roger
          I was on the lookout for just such an item at a realistic price for ages, I reckon $100 is just too much.
          I had figured it would be a good idea since I had changed to 33" tyres, but having recently had a chance to check my speedo against a GPS unit I was pleasently surprised. At 40, 60 & 80kph its dead on, at an indicated 100kph its really about 101 and at 120kph its about 123, close enough for me
          Maurice
