Hello,
Just went to fit my front ball joint spacers and have a question.
The four small studs that hold the joint to the upper A arm are a very tight fit in the ball joint (its all come apart OK)
Are the studs rusted into the ball joint or are they a press fit?
Either way, do I have to remove the whole ball joint to get the studs out or is there a way to get them out on the car.
regards
just thought, I could put it back together, and whack each one out in turn
regards
