I have std 15" rims at the mo, they have 265/70 15 110Q tyres, they are some unheard of cheapo a/t and awful on the road. I have read on here about 31" and 33" tyres, I cant find any markings on my tyres that say 31 or 33 so I've measured the radius from the centre of the hub to the top of the tyre and at best it's 14and a half inch, = 29" diameter. I assume 31" and 33" refer to the overall diameter of the tyre, will 31" fit on a surf that has not had any lifting kits fitted. The rear springs are quite new and the front looks quite high as if the torsion bars have already been adjusted a bit higher. If 31's will fit are 33's out of the question, and I've also seen some people have 32" will these fit without a lifting kit . I am particularly interested in th kumho 71 that are discussed in another thread, might even leave the stock rims on , although I was hoping to get some 16's sorted
) what the hells a panhard drop bracket!!! i wanna get some 33" and is the 1" diff spacer kit for the lift or the bigger tyres? cheers stormforce!
