Roof Light Bar
  • Roof Light Bar
    I know i'm rehashing old stuff here but someone asked for the info,
    When i was looking for a light bar i could'nt see anything on the market that i liked, most of the "bought" ones looked like half a roof rack,
    I made mine out of two 1mt lenghts of 20mm alloy box from B&Q and some 3-4mm flat alloy plate, First i made a card template for the side supports, when it looked right i transferred it to the plate and cut to shape, the most fiddley bit was getting the angles right for the contour of the roof, i positioned these a little more inboard from the edge of the roof than i wanted so as to miss the double skinning inside the roof, i used "bigheads" with double sided tape (to stop em turning) and 3/4" tap washers under the support feet to stop the water getting in (along with a little black silicon sealant) once these were in place i cut the box's to lenght and made up some alloy "plugs" to press into the onen ends and fixed them in place with alloy covered head pop rivets, then i drilled and tapped each end of both bars to take some threaded rod and s/s dome nuts, use locktight on all threads to stop em viabrating loose,
    Thats the main bars!! next i made the light holding plates, (X4) this is approx 30mm X 3mm flat alloy plate, bent and drilled and fixed across the two bars with threaded rod and s/s dome nuts, (used this throughout so it all looks the same and wont rust like regular bolts) at this stage i decieded to fit 7 amber 10mm leds along the front edge, i ran all the wireing through the forward bar and into the rear one via some "fluted tubeing" from VWP, also used this along with some terminal weatherproof ends to take the wireing through the roof, i wanted s/s bradeing but could'nt get it, this looks OK though,
    Thats about it as far as the bars go except to say i gave all the alloy bits a good going over with autosol on an electric mouse pad, it dose'nt need laquer as it's kept it's shine and only need a quick rubover with autosol when it dull's,
    I appoligise for the pic's of em on as i only put em on in the garage for the pic's, to see what they looked like, had to take em off again to get the truck out, now i got the clearance i aint got the time to fit em properly,
    The light's i used by the way are 3 1/2" blue glass spots (to match the six on the front) i also used two with amber glass on the front as foggies, Finally regarding the light fixing's i did'nt like the look of the threaded bit and steel nut, luckily i had some s/steel dome nut's the same thread, so i cut the thread to the right lenght and used them, i think it finishes em of a bit, and they wont be rusty the first time it rain's,
    Think some of these pics are in cinema scope (photobucket) Sorry
    I'll take some better pics when i get em on properly, you wont see all that wireing then,
    Which pics?
      Originally posted by MattF
      Which pics?
      Give me a chance!! Jeez
        Those roof brackets look lovely. Any chance you might be tempted to make
        some more up for selling?
          Be glad to mate soon as i have the time (and alloy plate) i think i chucked the template but i could take a pattern off the one on the truck,
            That'd be nice if you could. I'll definitely buy a pair of those.
            They look gorgeous.
              It really aint difficult to do Matt, try a few shapes in cardboard to see how it looks, find some alloy bar or bars, you could do it with a peice of step ladder like vince, i'd get the bar first if i were just starting, unlike me, i made the sides and then had to find summat to fit and look in scale with the sides, step ladder alloy was too big for me and i could'nt find any 20mm X 35mm box so settled on two 20mm sq boxes, the rest is drilling fileing and polishing,
              Like i say the most fiddly bit about it was getting the bends right so they sit on the roof contour and sit upright, loads of trips from the roof to the vice till it looked OK, The first hole in the roof is the $hitter, Loads of masking tape and good drills starting with a very small one (2mm) and watch it dont grab and go right in of the fibre sound deadening stuff wrap's around the bit and you cant get the ba$tard out,
              If you remove the top trim so you can feel behind the head liner to can feel where the double skinning stops, you dont want to come through behind that or it's a sod to get a bolt or whatever in there, i used bigheads, if you need any let me know, you can see one of em in this pic (nut's it's on photobucket hang on)
                cheers for the pics/ info again(yes it was i who asked lol)
                really really like the end plates look very original and professional mate,just gotta get off me fat ass and do it... got the angle eyes x4 sitting in a box for three weeks so far maybe if its nice this weekend ill do it (should that be weather or wife permitting!!? keep up the excellent mods mate
                  Sorry I hadn't popped up a response earlier Ian. Didn't realise you'd added
                  something else to the thread. If I do manage to draw a blank in making
                  some for myself, am I still okay to give you a shout to make some?
                    No worries Matt! be happy to do em for you
                      Cheers Ian.
                        please sir,can i be next in line lol... no rush etc and how much ya be wanting for such fine craftsmanship (grovel grovel etc)
                          Very tasty! Hard to believe those brackets are home made!
                          Derek :
                          1990 Hilux Surf SSR Ltd
                            If i can source some decent alloy plate i'll be happy to "knock up" a couple, thats assumeing i ever finish this sodding bedroom and hall, just cover the post etc and i'm happy,
                            Cheers Delboy for the comment
                              Still having fun with the decorating then?
