has anyone else fitted one?
reading the set up procedure the engine is to be run up til the gauges moves to 3/4 then adjust the fan to cut in at that point, to me thats worringly late for a vehicle with a temp prob, they instructions say that 3/4 on the gauge is only 5 to 10 degrees more than normal.
if no one has anyinput on this i will be ringing kenlowe tomoz one to order another silicone band (see viscous fan thread) and two to get reasurance before i start the setup procedure, plus i think i mite wire up a digi temp gauge to see what temps it is running at as the gauge doesent show temp, my works vans gauge goes from 70 degrees to 115 degrees - normal running is 75-80 towing it goes up to 85-90
disco now gone aswell
