If it was a blockage anywhere, the coolant wouldn't have come out
at all. You're flushing using the coolant paths, so it can't be blocked
otherwise it would just spray back out where you're putting the hose
in. Must be some other reason. Did you check the rubber hoses, BTW?
Rethinking that bit, did you mean the coolant coming out was different
colours depending upon which set of pipes you were flushing through?
disco now gone aswell
