2.4TD power upgrades???
    not backwards
    DONT plant it on full lock in reverse, see post by andy_enuff for how NOT to reverse a surf! - he rolled his.
      Mine is poor until it gets going?
      What comes around goes around!!
        Ray
        Have you, or anybody who has turned the air intake round have a picture please Thanks.
        Regards
        Kev.
        2.4 black beast
          i can take a pic for you but it doesnt show much - undo the elbow before the airbox and face it backwards, ive done mine and its loud!
          Tim
            I did my top seal on the fuel and reset the ecu(disconnect the batt`s for 15 mins) much better drive etc after
              Cant get em over a bump eh!! mine was similar and im sure its injectors, as said injector cleaner is a good idea especially if your fuel is a bit suspect, and regulat filter changes, A point made to me by Bushwacker was is your auto transmission fluid ok, ie- low, high, old and nackered,??? Ian
                That could be a possible reason. Mr Paranoid here, , had the
                vehicle fully serviced when I first got her, including all oils, filters, belts
                and rocker cover, thermostat and rad cap, plus a few bits I've forgotten.
                That maybe why mine has always been perky.
