33" tyres are way heavier than 31's, and the steering stabilser is often worn after 10 years anyway, so after fitting 33's and 4" Superlift lift kit to Ashleys truck last year, he was having odd steering issues, so we fitted a Procomp Heavy Duty Steering Damper kit, which did improve things significantly.....
Its just a straight swap for the original, so not worth any 'fitting guide' on here, but here's a pic to show the weedy looking original next to the new one...
But we felt the front wheels were still a little jiggily, so it can back to be fitted with a 4x4Toys 'dually conversion' Which is basically another HD damper, mounted in tamdem to the first, on custom brackets.
We mounted one each way round to make sure it got the exactly the same push-pull force in either direction, as we felt the wheel was slightly easier to turn one way than the other with just one damper fitted.
Test run up a greenlane and on the road resulted in a happy Ashley and happy truck.
