Wot vehicle is it from so I can find the transfer box for mine ?
Project '2 door'
My one is from a Blazer, I think most Chevy auto 4x4's have NP t/cases. It probably overkill, but makes life easier. (apart from lifting it up to mount it!!Originally posted by Vagrant No2Wot vehicle is it from so I can find the transfer box for mine ?
Yep , with your help .I will use a seperate switch or leave it off .Originally posted by vatchmandid you sort your g/box prob out rick.
I think Tony has the answer with a Chevy Blazer transfer box as it appears to bolt to the TH350 . There is a Blazer autobox and transferbox on ebay but a bit far to go for it .That or import the Downey kit .
Tony always has the answers but never tells me until he has done them !
or I have struggled to get the answer he already knew .
id go for the downy kit,just think off the extra weight of the blazer transfer box.coupled to the th350.Originally posted by Vagrant No2Yep , with your help .I will use a seperate switch or leave it off .
www.overfab.uk
