Originally posted by TonyN
Project '2 door'
Nah, its got be as Toyota as possible, If I could get a Lexus quad cam V8, the Rover V8 would be in the bin!Originally posted by BUSHWHACKERJust a thought, wouldn't it be easier to get a Range rover with a V8 in it , and just swap the body with the Surfs?
Has Linda shrunk to midget size or are they big wheels?
Looking good Tony. Makes my little project look lame (It's good practice for when I get my BJ40 though). I wish I had the room. Local corporation style lock up garages leave no room to work once the truck is inside, so I am reliant on the weather..............sigh! I suppose I could lose 4 Stone, then there would be room for me and the truck.It's only a hobby!
They are Huge!!!
@Danno - not you. I made him remove everything from the horse yard and create a bigger muck heap, which meant the Caravan had to move, so we could actually get to the 2 door again.... and I went off doing horsey things this morning.... came home to find the wheels nearly on and the axle stands gone. Can't wait to drive it...Linda
www.4x4toys.co.uk
Andy, this the chart I was looking for for you, its based around Petrol V6 trucks, but might help give you an idea.Originally posted by AndyLalaIs there anywhere were you can calculate how different gears may affect the powerband of the engine if you don't regear the diffs...?
Just thinking out loud... could I get 33's on without having to regear... and what would the penalty be...? could that regearing not be done in the transfer case...?
If you have a 150hp V6..............Originally posted by AndyLalaSo a G145 Axle gives a ratio of 4.875:1...
Does that mean I could get away with 35" tyres....?
With only the speedo to worry about...?
so a little work on the turbo... maybe those washers after all...
and 33" with that Superlift (Truspeed) electronic gubbins box to bring the speedo back...?
So it pulls off a little slower... that is not the end of the world...
Originally posted by TonyNIf you have a 150hp V6..............
Found something of interest for the rear end...
http://www.pirate4x4.com/articles/pr...iews/eor_3link
A completely mad rear end... note the rear disc brakes too... totally sweeeet as they might say...
I know where there is two LS400's is a breakers yard. Both have engines. Let me know if you want details.Originally posted by TonyNNah, its got be as Toyota as possible, If I could get a Lexus quad cam V8, the Rover V8 would be in the bin!
(They are in Ireland BTW)
OK, back to this project, we've settled on a motor (ATM!) a Chevy 305ci (5L)...
(top motor, one on floor is the Rover its replacing) that came out of a friends day van that now has a 350ci motor in it, so it was time to hit ebay to find a tranny for the beast.
I won a NP302 T/case, which was a good start, but when going to collect it the guy had a whole slushbox/Tcase in the garage, so the deal was done and we ended up with a TH350 (non-electric) Autobox and a NP305 T/case!
It was a toss up for the T/case, full time 4wd (302) vs part time (305) like the 2nd gen surfs, but I couldn't afford both so we got the TH350/NP305 combo as one unit and called it good.
Was a heavy bugger to load in the back of the truck, but its home now and taking up space in the garage.
