Just found this on the 'bay' :http://cgi.ebay.co.uk/Toyota-6-Cylin...QQcmdZViewItem . Would give my old girl a boost !
Should I fit this ?
Dunno about straight fit, the IFS was partly introduced to give clearance for the V6 engines, so you may have to 'redesign' the sump a little, or fit a small body lift (my preffered option)Originally posted by Vagrant No2Wot , you going to fit it for me ?
Tony , these are not a straight fit are they as IFS was fitted because of the engine size ?
You'll have to make engine mounts, and fiddle with the gearbox crossmember mounts to get it to fit in the engine bay nicely and still leave room for the rad, Is it actually a 7M motor like the supra motor or something different? the 7M will fit in a 2nd gen engine bay, but it must be longer than a Rover V8, and these don't leave much room for the rad in MK2 pickup.
I really want to fit wot you had in your pick up . Rover V8 with autotrans with the Hilux transfer box . Will need to commision you to make up the tailshaft adaptor for the autobox . Chance to use your new lathe .
All along way off at mo , just dreaming
OBVIOUS ANSWER = supra twin turbo lump!!!!!Originally posted by TonyN....Is it actually a 7M motor like the supra motor... the 7M will fit in a 2nd gen engine bay
traction issues could be interesting, but what a beast it would be!VW Taro (hilux single cab PU) - 31" rubber, H/D springs and shackles, LSD, 4 pot front callipers, 2.4 N/A Flymo engine..
