Originally posted by laser_jock99
3" body lift
Yeh as i said on the 4th post apart from the bumper brackets the only mod was the steering column no mods on auto shifter or transfer and my rad is in the same place as before,if you have a manual you most probably will need shifter mods,but none of this really matters cos your gonna be saving your self £700 anyway if you use Crawlers kit.
i got a roger brown kit and it was a piece of !!!! to fit... only trouble was beacause its made for a left hand drive, the steering column extension fouled the exhaust... but the 2nd gen wouldn't have this problem because the column runs to a different place... it really is as easy as un bolt, jack up, fit spacers, bolt up again... i did it in a day on my own, but took 6 weeks to get the column sorted!
give the bolts a spray of lube a few days before and you should have no troubles!...
special tools i used were lengths of wood to spread load along sills and a 2ft breaker bar for the tight bolts.nee nar nee nar, i'm a fire engine!
