Hello... I currently building up my Surf and I am planning on running 35s... so I found a company in the US (ringpinion.com) who says they can supply me with everything I need. ie. Front & Rear 4.88 ring & pinion set with complete rebuild kit.
I have given them my axel code (G295) and have told them that I have an 8" ring diameter, 4 pionion LSD and IFS.
My concern is that I was told that the parts from the US won't work in the Surf...
Is this true??
Is there any other info that I need to give these guys or anything else I need to ask about the kit before I buy? I really can't afford to end up with a kit that won't work.
Has anyone change their diff ratio and if so do you know of any issue that I should be aware of?
Thanks
Justin
1993 Toyota Surf 3.0 TD ...
Soon to have...
4" Pro Comp stage 2 liftkit, 4 crawler 2" or 3" Body lift, American racing 15x12 running 35s, 4.88 running gears, Front mount intercooler, smt6 piggy back ecu
Is this true?? Is there any other info that I need to give these guys or anything else I need to ask about the kit before I buy? I really can't afford to end up with a kit that won't work.
Thanks
Justin
Soon to have...
