Guys,
My rad fluid looks more brown than Red/Pink. I just dont want to give it a "simple" flush, I want to use a good radiator cleaner in there to get it back to "factory fresh". Can someone suggest a good radiator flushing fluid for me? It needs to be gentle on any alloy bits in side the engine, remember.
Method:
1: Run the engine to agitate all the solute into suspension and get coollant warm
2: Set heater matrix to full hot, remove cap and unclip lower hose to drop the coolant out
3: Refill with running water, add the Radiator Cleaner and let it run for a wee while, surging the engine intermittantly
4: Drop cleaning water out again, run tap-water thru the system (stuck into radiator filler hole or do I plug it into top hose?) so that it runs clear at the bottom hose. Should the engine be running at this point?
5: Reconnect everything and add Toyota Red Coolant mix to the engine, making sure matrix is fully open.
6: Run engine with cap off, then refill if there is a drop. (how long should I run it, what am I supposed to watch out for?)
Is this right? Anything I have missed? Is it a better idea to add the radiator cleaner to the original coollant and run it around for a day or so? or is it fine to just drop as much of the dirty stuff out and add water + Cleaner for a second, 10 min static engine run?
Do I HAVE to do that "Coolant Burping" trick or is that shown to help ppl who have a particular problem with cooling?
Thnx a lot
Udhi
Method:
Thnx a lot
Udhi
