Can anyone help me please. Problem is the priming pump on depression is squishing out diesel from somwhere just underneath the thing you depress. It seems to be sucking air back in. Could this relate to my progressively worsening current engine problem, which is excessive reving of its own volition, black smoke from the exhaust, and the engine cutting out on me with much sputtering both at speed and on slowing down. If the primer pump is faulty does anyone know where I could get a new one or if the old one can be re-fertled so to speak?
Priming pump
1. It could be a seal on or around the priming 'handle'Originally posted by GillianCan anyone help me please. Problem is the priming pump on depression is squishing out diesel from somwhere just underneath the thing you depress. It seems to be sucking air back in. Could this relate to my progressively worsening current engine problem, which is excessive reving of its own volition, black smoke from the exhaust, and the engine cutting out on me with much sputtering both at speed and on slowing down. If the primer pump is faulty does anyone know where I could get a new one or if the old one can be re-fertled so to speak?
2. Try taking of the fuel filter to see if this is the problem - could be on cross-threaded, not tight enough or some air locked in side
3. After taking of the fuel filter dont forget to re-prime the pump by removing the out-flow pipe until you see a little fuel and then put pipe back onGaz
Yup, this is a sympton of sucking air.Originally posted by GillianIt seems to be sucking air back in. Could this relate to my progressively worsening current engine problem, which is excessive reving of its own volition, black smoke from the exhaust, and the engine cutting out on me with much sputtering both at speed and on slowing down.
Its leaking anyway, try and strip the top of the fuel filter housing and pump to see if you have any split seals/o-rings etc.4x4toys.co.uk - Keeping you on and off the road...
