I was going to suggest the same as stara and skiper but re-read it and noticed his probs went away for the summer?? Unless he got the job 'done' on the plugs at around May and now he has got a fuel leak. I had two leaks one sraight after the other. The leak on the engine side of the fuel pump meant she started after coaxing and then ran badly. The leak on the opposite side of the pump meant there was no juice getting to the pump and she wouldnt start at all. Check the jubilee clip at the feed to the pump is on right and isnt biting into the hose.
PS did you ever get your cheque Skiper? (stick an edit onto your post to avoid hijacking
