Hi Guys,
Recently fitted rear coil springs 20% stronger, from Milners. Frone was still bouncy, so fitted front non adjustables gas shocks from milners, but basically not much difference, still bouncy!.. Front height from under arch to centre of hub is 460mm The rear height is 540mm measuring the same from under arch to hub centre. Would appreciate some advice and where to go next.
Thanks.
Jamie
Thanks.
Jamie
