Vibration from under Gear Lever
  • Vibration from under Gear Lever
    Hi Guys I have a Vibration noise that sounds like its comming from under the Gear Lever on my 93 2.4 Auto . It only happens when moving at around 2500 rpm . Gear selection does not make any effect . I have looked at the shields and they all look fine as does the exhaust and anything else i can get my hands on . The prop has been greased and looks to be ok . Its driving me nuts . Any ideas appreciated .
    It must be a engine thing, seeing as its RPM specific, I'd give it a service and check all the belts, fluid levels in the power steering pump, and pump, aircon alternator and fan bearings etc.
    Pull the bellhousing lower cover of, and check your torque converter/flex plate arn't loose.
    Then look at your engine and gearbox mounts.
