Can anyone advise me on the correct tyre pressures for Hankook Dynamic Radials 215/R15/100S. Are these the standard size tyres for this vehicle?
The reason I would like some info is because I have had a little rear end twitch and you know how dangerous that can be!
Neil
Neil
As to pressures, try something around 30 - 32 psi. The only word of caution is that if the tyres are the ones the truck came from Japan on you may never get good grip - they don't seem to travel well. Also in my experience Hankook tyres are ok until they're about half worn - I think they put the naff rubber at the bottom.
