Need a quick answer
  • Need a quick answer
    Help Started to do coolant change as next week we r going to have -temps. so need coolant change.
    Have taken off smash guard and can feel the drain tap on the bottom off the rad but can't turn it, need little jap hands i think !!!!!. Do i have to take off the air con. rad so i can get to it easyer or have i missed a cubby hole some where ?
    P.s It's started to dark so got 2 b quick
    Get Them B 4 They Get U
    I did mine recently and found that GENTLE use of a pair of molegrips got round the fat hand problem!
    Hope this helps.
    A positive attitude wont solve all your problems but it will annoy enough people to make it worth the effort!
      Hi M8
      Do what the man KEEF says but be gentle the drain taps plastic!!
      Or just remove the bottom hose, will flush better with the hose removed.
      AnDy
        You can get at it easier by going in from the side in the passenger side front wheel well. Just have a look around and you will find the place to go in from. I can get my arms in there so as long as you don't have weightlifters fore arms then you should be ok.
