I was out in my Mk4 Hilux this morning and noticed how much smoother the ride is in comparison to my gen 3. What will cure the harsh choppy ride? is it he shockers which look to be original 1996 parts or the springs also original or a combination of both? If I change the front shockers It would be easy to change the springs at the same time but then I would have to do the rears as well. Any suggestions?
gen 3 choppy ride
Well the suspension is to all intents and purposes the same, but the shock and spring rates are different. I guess as the surf was aimed at the "more sporty" market they gave it a firmer ride, combined with the larger body weight of the land cruiser stabilising things.
Annoyingly all the after market stuff seems to make everything firmer still!More Lift.
More Tyres.
More Engine.
Sounds about right as the colly is a fair bit heavier. I need stiffer springs on the back as I carry extra weight on a daily basis so I thought about a complete upgrade front and back, if I lift it a bit I can get some bigger tyres on as well both of these will give a bit more ground clearance on the lanes near us. I like the look of the Toytec kit whats the cost?Old enough to know better but then again.....
