Hi all,
I've read a few posts but hoping for something more definitive with this one as they don't all cover the same points i'm looking at.
I've just purchased a tidy 1992 SSR-G 2.4 (Gen2?)
I've got no heat from the front or rear.
Things i've checked.
I've ran it up with the thermostat rad cap off for 30 minutes to try and bleed any air in the system but nothing seemed to come out.
Although the weather is not great the pipes and hoses from the thermostat housing leading to the heater matrix/bulkhead didn't seem that hot which suggests an air lock perhaps?
The engine runs up to temp sitting perfectly in the middle of the gauge and the fan kicks in as normal. I'm now thinking something more expensive at play as i can't find an issue. I'm going to try and flush out the matrix at the weekend but as i don't have heat in the rear i don't hold much hope.
Any help or suggestions would be great.
Thanks in advance!
Chris
- Slider control - friction on the slider seems to be ok
- Coolant level - It's right to the top of the expansion tank
Thanks in advance!
Chris
