Having replaced coolant and finally topped up I have about 55% antifreeze. The temperature guage remains the same as normal, just under halfway. If the engine got any hotter when running and replacing coolant could this cause head gaskit to leak or head to crack? I intend to drain radiator a little and top up with more water to lower % of antifreeze.
How would I know If there was an air lock in system and remove it. How do you know when the gaskit or heads gone, would engine sound any different??????
