Hi, has anybody fitted these recently. Are they ok, I noticed that some springs tend to give you a lift rather than just stiffening. I don't want a lift.
To answer ya Q?
I fitted some Milner 20% springs some 4 Years ago or so n not had any probs with em ( can't remember if they changed supplier of if they came handed)
One spring slightly taller for the O/S/R (drivers side)
Hope this helps
13+ Years of Surfs ..... n Faultless to a "T" is my Yota !!
They lifted mine and the ride is a little too harsh for me. They lift it slightly due to the weight of the car not compressing the springs enough as they are 20% stiffer.
I can load the rear up with rubble or sand cement and the tyres give before it sits anywhere near the bump stops.
Fingers crossed the new springs going on today will bring it all back to normal again.
