Prop shaft greased?
Help with gearbox!!!!!!!!
not in a while!Had a prop shalf uv
replaced couple of years ago felt a bit like that!Last edited by cold water surfer; 12 May 2015, 21:49.
Well its been a couple of weeks now and after i flushed and filled to the correct level the gearbox seems fine!! no death noises and smooth operation!think i may of saved it in the nick of time!My local mechanic was very quick to right it off but the noises were very alarming, on his advise i managed to get a replacement box but now it seems i dont need it.Im going to keep it for a while longer and then try to sell it if the box still works well. The prop shalft uj was knackered but an easy fix.Thanks again for your wisdom and advice, ive dipped in and out of this fourm over the years and have always been helped.Time to give the old girl a bit more care and attention.
