Hi everyone, was hoping for a bit of wisdom regarding some screeching noises which appear to be coming from the auto box! Oil level was low and dark! Drained and topped up but noises still there , had no choice but to drive her 40 mile round trip to work today as the bloody exhaust fell off the camper yesterday!! Noise seemed a bit worse now!! Going to drain again later as I only put a few litres through it .Best wheels I've ever had and want to keep it forever!Any advice would be good.
Help with gearbox!!!!!!!!
Dark oil is not a good sign...indicates either heat burning the oil or clutch and break band wear.
Screeching rather suggests the clutches or brake bands have worn out or possibly stator sprag clutch in the torque converter...all of which would indicate its new gearbox time...or rebuild time.
I hope to be wrong.
How did it drive going to work?
Thanks for some advice andyverran .Got a friend having a look tomorrow will share your thoughts, I'd go for a new gearbox if required as I want to keep her on the road, been processing waste veg oil for 7years and it's saved me a small fortune whilst putting a smile on my face every time I drive it.
Thanks again Andy , my mate dident really want to know! Too big a job! The car drives fine but I feel like I'm just waiting for it to go bang! Is there any one out there willing to change the gearbox for me, otherwise may think about finding another and keeping mine for spares. Can tow it a reasonable distance.
Hi , about half a washing up bowl came out I guess about 3-4liters, and roughly the same back in. Dident check with engine running ! Checked when hot and looked ok , the next morning checked cold and was very low topped up again until it looked ok , haven't had a chance to look at it since. I intend to flush and fill again today as I got another 5 lt yesterday. Will check level with engine running will this give me a better reading?thanks for your interest.
Originally posted by cold water surfer View PostHi , about half a washing up bowl came out I guess about 3-4liters, and roughly the same back in. Dident check with engine running ! Checked when hot and looked ok , the next morning checked cold and was very low topped up again until it looked ok , haven't had a chance to look at it since. I intend to flush and fill again today as I got another 5 lt yesterday. Will check level with engine running will this give me a better reading?thanks for your interest.www.overfab.uk
Yep you were right still low, I heated engine and drained out all oil , left it for an hour or so. It took 5lt before it showed bang on the mark whilst checking it with the engine hot and running.After a spin down the beach the noises are still there and seem worse in 1-2 whilst coasting , the car drives fine but the gearbox sounds like it's dying!!!
Originally posted by cold water surfer View PostYep you were right still low, I heated engine and drained out all oil , left it for an hour or so. It took 5lt before it showed bang on the mark whilst checking it with the engine hot and running.After a spin down the beach the noises are still there and seem worse in 1-2 whilst coasting , the car drives fine but the gearbox sounds like it's dying!!!www.overfab.uk
