Folks,
Had a little search and didn't turn up any clues...
My wheel was not central on the column and the flaky indicators that resulted are driving me mental, so I've lined up the wheel with the column marks (indicators now flick of for the same amount of steering input in both directions).
The wheels now point off to the left (about 90 degrees of turn on the steering wheel to correct it), I looked to turn the track rods in/out on each side to bring it back to straight ahead, but there's no adjustment left in them.
I measured the length of the arms and with my tape they're 340mm (manual says 328.5 as a starting point) and both are the same.
what have I not thought of?
Pitman arm is aligned to it's marks (not that I expected that to have moved but checked anyway).
