1993 2.4 LN130
2WD: Sometime ago I replaced the main propshaft UJ's as one had broken up making the vehicle undriveable. Since then I've had a noticeable (it may have been present at the same time but not noticed due to main prop vibration) vibration between 50 - 60mph which is only present under acceleration - disappears on the overrun. From the frequency of the vibration I'd say it's faster than wheel speed and more like prop speed and appears to affect whole car rather than just steering.
Double checked to make sure main prop was re-assembled in phase.
I can feel some play (not sure quite where yet - certainly some in the splines) in the front propshaft, but I assume this isn't spinning in 2WD?
Any thoughts?
Jonathan
Any thoughts?
Jonathan
