Previous owner replaced both inner and outer and also sleeves/clamps.
As some may have read that I had a bad pull to the left even after having the front camber/caster/toe set perfect. Mechanic adjusted both track rods an equal 1/4 turn and this straightened the steering but obviously this has meant toe etc is incorrect against factory settings ( albeit total toe is equal ). He pointed out that the drivers sleeve is wound in all way at the wheel end and passengers side rod is about equal at both ends.
What's the best way to correct this is possible to give a basic equal starting point or does this meant something is wrong? Mechanic reckons both sleeves should be equal ( ish ) unles something is bent..
Thanks!
Thanks!
