KZN130 Timing/Cambelt change?
  • KZN130 Timing/Cambelt change?
    I'm just wondering when it needs changing? It's not been done in over 9 years so I'm going to get it done asap. I've tried viewing the service schedule at the bottom of the forum but it's unable to open the page
    Thanks in advance
    Thanks in advance
    Its due on time or mileage which ever comes first. Either way after 9 years your due a belt change asap
      Use the "search" top of page.
      Lots of info,pics, etc,
      Look at Roughtrax web page, parts supplier.
      Type in your vehicle details & search cam belt.
        Thanks guys. Will get it changed after Christmas, fingers crossed it will be ok until then. I've found a few guides and other info but unfortunately after a search on the forum and Google I couldn't find the proper time intervals to have it changed.
        Found the kit for £60 for an aftermarket or £100 for a genuine on Roughtrax so will buy it from there and get it booked in at the local garage to get it fitted. Would the aftermarket one be ok or shall I get a genuine one? Money is quite tight at the moment so trying to save money where I can.
          3.0TD Belt change is relatively easy and can be done in less than one hour with no special tools. Consider changing the water pump at the same time.
          Belt wise when I had the land cruiser changed I used genuine toyota belt & pump.
            I was tempted to try it myself but it's not something I'd trust myself with. I've found this one on Roughtrax http://www.roughtrax4x4.com/?doc=16&cid=613&vid=1907. Anyone ever used one of these belts? I believe at the moment it actually has a Mitsuboshi belt on it.
              Belt
              Think Mitsuboshi is the cheap budget brand Milner stock. For the price difference I would be tempted to go Genuine/Gates/Dayco. Genuine belt is around £30 from the main dealer.
                On the link from Roughtrax I posted it says the belt will either be a Dayco/Mitsuboshi. Think I'm tempted to go for the full genuine kit they have here for £100 just for piece of mind http://www.roughtrax4x4.com/?doc=16&cid=613&vid=1400
                  Hmm, "cheap budget brand", eh? Still, it has lasted 9 years, so far, so not bad for a 'cheapie'....
                    Hopefully it will last another month haha .
                      Fingers crossed!!
