Coolant filter
  • Coolant filter
    Just thought I'd share a little experiment I did on my Surf. Being of a slightly paranoid nature when it comes to my 2.4, I am constantly looking for ways to monitor my coolant. On another forum I saw a bit about coolant filters on larger diesels (american trucks) and thought little of it until I realised I would be able to look at the coolant condition without opening the rad cap. It has always bothered me that I can't do this on the Surf in the way I could on anything with an expansion bottle like my old VW.
    So a couple of weeks ago I fitted a glass fuel filter in the line to the rear cabin heater. I had removed the heater a few years ago anyway so it was redundant.
    This is what I found when I looked at it yesterday:
    Emptied out:
    Keeping in mind that this is on a bypass from the main flow of coolant, that looks like quite a bit of crud to me! I fitted a new head about a year ago and have done 4000 miles since. It has been thoroughly flushed three times in that time but it looks like I still have a reservoir of crud somewhere.
    I used an ordinary glass filter from ebay with tips for 8mm ID hose. I put it nice and high for accessibility and away from the worst of the heat because of the plastic tips. I would use one with metal tips if I was doing it again.
    I had the rear cabin heater line available anyway, but I didn't like the idea of putting a filter into the rad top hose or the main cabin heater hose as I had seen on the other forum in case it blocked and reduced the flow. Fitting is simple as the lines for the rear cabin heater start at the thermostat housing.
    This is how it sits in the engine bay:
      Interesting post..
      .... Which was nice.
