Hi Guys,
New to the group.Iv recently bought a 1993 SSR-G,2LT with manual box.My issue is the 4wd system,or should i say lack of!The button on the small shifter doesnt seem to be doing anything.Iv tested the actuator on the front diff by switching the vacuum lines around on the VSV's on the drivers side valance.Jack up the front left wheel,switch the pipes over and give the wheel a spin and i can see the front prop spinning back to the transfer box.Disconnect them and the wheel is free spinning again.So then i thought the switch on the lever maybe be faulty...pulled out the connector and bridged it with a piece of wire but to no avail.Any insight guys?could it be the 4wd ecu/relay that i hear clicking under the dash?
Iv tried putting the lever in 4L,and driving forward and back to engage.In 1st gear the revs are high,as if it has geared down but im 99% sure its still in rear wheel drive...if thats possible?!Also when i move the lever from low to high range or vice versa,there is a noticeable click sound coming from the top of the gearbox.
