On coming back from a long trip to Inverness, I got a sudden blow from the exhaust system. I figured a hold in the exhaust or down pipe as it was so loud, but on inspection later, it appeared that the lambda sensor had come out. Not quite sure how, as it is held on by two nuts, which improbably must have worked themselves loose and dropped away.
Anyway, good news in a sense as should just be an easy fix back. However, I cannot for the life of me work out what size nuts I need to replace. I thought it was an M8, but the nuts start to go on, but stick almost immediately. I've done a wire brush and oil on the threads, but this hasn't made any difference. M10's were too big, so I presumed M9 as I had heard these are sometimes used on motors / bikes. So bought a pack of these on Amazon, but they arrived today, and they are too big as well.
Does anyone know what size I need? Also, does anyone know where I can get a new gasket for it as well? If not, I'll have to use a liquid gasket I guess.
