Hi All,
Not long after I had finished building a sleeping/storage platform I noticed a small brake fluid leak coming from where the two pipes run along/over the fuel tank.
I have got to the point where I managed to get all the bolts off and managed to get the pipes disconnected, took a good few hours due to access issues and back problems but got there!
When I went to make up the new pipes I thought I had left at least one of the lines connected to I would know which pipe went into which hole on the brake compensator valve.....to my horror I found that I had not and now I can't remember which one goes to where
The pipes run parallel to each other from the front drivers arch to the compensator at the rear, I've down loaded the kzn130 workshop manual but it doesn't help.
Can anyone help with this?
