I've decided my Surf has got a saggy rear end, after all. I don't know whether the ride is good or bad for a 4x4 as this is my first. She feels wallowy, vague and rolls, compared to a normal car...
Anyway, the saggy rear seems like a good place to start. I've searched and found loads of info, though I'm not any clearer about what to do.
Clearly I will need a set of springs but will I definitely need a spring compressor? Opinions seem divided.
I want to solve the rear sag but not at the expense of awful ride, so which should I go for out of:
1. Milners "20% stronger" springs here.
Or
2. Roughtrax's 2" lift springs here.
Or
3. Some other option.
I like the idea of a 2" lift (front to follow?) but not at the expense of ride/performance (my off-roading is limited to farm tracks and fields- not "enthusiast off-roading".) I don't routinely carry heavy loads nor tow.
Therefore, I might just go with the Milner option based on lower price. I wasn't going to do the shocks at this stage...
Thanks for any advice re: spring choice, need for a spring compressor and whether I ought to do the shocks, too (if so which budget option?)?
Or
Or
