Hi all, ever since I replaced my shocks and springs, the vehicle tramlines quite badly and I always feel to be correcting the steering.
Checked all mountings, nothing loose etc. The springs from RT were the standard height but stiffer spring. Tyre pressures as they should be.
If it's sitting higher as the spring doesn't compress as much, would that affect the castor / camber angles?
I have found that the toe in is 2mm +/- 2mm according to roughtrax.
Does anyone have the full info before setting off to garage to have it checked, or any other advice that I can look at.
Many thanks
Andy
Many thanks
Andy
