Hi,
I seem to have sprung an oil leak from somewhere around the Aircon unit. I've just done a service oil/air/fuelfilter on her, so I made the obvious check around the new oil filter to see if it was seeping from there. Seems ok.
The oil is very clean and seems to be soaking the aircon rad and dripping from there onto the protection plate and cross member.
The oil is not smelly like cat pee but it does seem to be cleaner than the new oil. (that gets dark pretty much straight away)
Oh yeh, I used a funnel during the oil fillup so no spillage from there. The diff area is as clean as a whistle.
The oil dip stick does show it to be at max level. Could I have blow a gasket or something through over filling?
Any Ideas guys?
Any Ideas guys?
