I've just got a set Goodridge hoses from Roughtrax and have had a weird problem fitting them, I got one of the old ones off ok but when I tried to get the new hose on it would not go on.
The union on the metal front brake pipe (caliper end) has slightly flared out on its un-threaded end preventing it from going into the new pipe thread, the actual pipe goes in ok though.
I managed to get the old pipe back on for now,it looks like the union has been over tightened at the factory causing it to spread at the end. Has anyone had this before?
I don't want to replace the metal pipes or unions if I don't have to especially the inboard ones, I could probably true up the unions with a needle file but it will be a pita!
