Hi all. this is the underside of my 93' 3.0l surf. My oil leak is coming from the flange as it is the highest point of the oil stain. Is this the possible source and a common fault or have I missed something else. It can't be the drain plug as the oil has moved up and forward from the direction of travel. see pic.
Any thoughts before I have a go or put it in a garage. (this is the first mechanical issue in ten years. not bad eh!) Thanks
