SSRX 3.0 Axle weights.
  • SSRX 3.0 Axle weights.
    I've got a 94/95 SSR X 3.0 Auto Diesel and very nice too.
    Now:I want to register this vehicle in France and I need to find out a few bits of info:
    1.Total Weight.
    2.Total Travelling Weight.
    3.Max Front axle Weight.
    4.Max Rear axle Weight.
    Can anybody help?-I know it's a pain but that's French bureaucrats for you.
    As a supplementary question-why do I get a loud knocking sound when I'm on full lock at low speed?The sound is from the front end joints and only appears on full lock.
    Many thanks
    Fatboy
    the noise will be your steering stops - grease them up and it will stop.
    Its one of the most satisfyingly easy cures known for any surf problem!!
      1.Total Weight.
      Many thanks
      Fatboy
      I know the total weight for MOT purposes is 2048kg (unlaiden) for the 4runner 3.0TD so i guess the surf would be near enough the same. As for the exact max axle weights i cant help you soz, but would think its vehical weight + max load weight then split one third front max weight and two thirds rear max weight.
      Hope it helps.
      BEWARE OF THE REAPER
        Total weight
        I have a ssrx 3.0 1994 standard except for stainless A Bar. Put it on my local weighbridge exactly 2200kgs. full tank of diesel + me wife and 2 small kids. Hope this helps
        Neil
