Hi all,
The upper rubber PSU reservoir hose on my 3.0 started leaking a few months back, from the lower joint onto the metal union, and once it got bad enough, I finally pulled it off, which destroyed the old original hose, and tried replacing with a length of suitable rubber hose.
After 3 or 4 attempts at slightly different pipes, rubbers, diameters, lengths, jubilee clips, cable ties and every other ###### variable I could think of (and having fully degreased the metal union each time), it still leaked about 500ml per week in normal use, with me having to use thicker std PSU fluid instead of ATF to stop it pouring out and keeping it usable.
I finlly capitualted, and bought the genuine shaped pipe from an ozzie dealer (who got it from Japan), along with original genuine clips costing a pretty penny to get shipped... and still it leaks
I've reseated a few times since, trying different sealants - rubber tyre cement, marine grade silicon, chewing gum and the thing still ###### leaks - it's driving me NUTS that something so simple can be so hard to fix!!
Has anyone had a similar issue with this pipe, and what did they do to seal it?
I'm really hoping I don't have to replace the metal union as this appears to be a single piece servicing the AC pipes as well, and I expect disturbing the other 3 seals on the other hose joins will give just as much bother.
