Only had the Surf for about 6 months so doing some of the maintenance jobs for the first time. I had quiet a lot of brown gunk in the bottom of the bowl strainer which was already fitted to the car so, as I am currently running a 50/50 Veg/diesel mix, thought I would clean it out and fit a new fuel filter. Thought I'd have a look inside the filter which has been in the car about 8000 km's. (see pic)
Not as bad as I expected but you can definitely see the deposits on the filter paper. Thought I would post up as I couldn't find anything on this as I was searching.
I also noticed (see picture) that the sensor on the bottom had the wire cut? Can anyone tell me what this would do and if its a problem not being connected?
Truck all back together and seems to run fine.
Appreciate any comments,
Thanks Nick
Thanks Nick
