My 1996 KZN185 3.0td suddenly cut out as I pulled into my drive then when i tried to re-start,it starts normally then cuts out immediately.
I have run through all the ECU pinout and component tests which have been inconclusive, I suspect either the Crank position sensor or ECU.
Has anyone had the same problem or got any idea please??
