Hi well found my new surf a few months back and here it is
Right the problem i have is that on slowing down under braking it shakes it self to bits and with the rear drums getting hot thought they my be wrapped so started at the back and worked forward.I have searched on here and done everything that has been suggested and cost a fortune but it still shakes.What has been done all shocks/rear springs,drop links,front wheel bearings,arb bush's,disc's pads(all pistons free),shoes and drums(with new springs etc).I adjusted these from what i read on here letting the handbrake do the adjusting when fitted.Now with the new rear drums on they still get way to hot so took it all apart again to day stripped all brakes back and front and checked all suspension and the drums are still getting hot.I even took it to a long hill put it in neutral on both sticks so transmission was disconnected and it still shaked.This is now driving me mad so any help would be great.
 ) now i guess these could be cause's of the hot running of rear brakes but not the shake.
