finally got round to fitting new front callipers
old ones, one or more pistons always seizing
tried to flush fluid at same time , front fluid clean and bleed I think but the bleed screw on rear cylinder's seized so i'm scared of snapping it , could only drain / bleed from the load sensing valve.
now the pedal is very low , does stop but poor braking
I don't think the pedal is spongy just low
pedal was fine b 4 .
have I done the master cylinder seal with all the priming / bleeding ?
I think ive shifted all the air ?
am I right that air in system would give a spongy pedal ?
any tips to undo the rear bleeds ?
tom
tom
