hi all , just until yesterday I used to get no cluncking when moving gear stick and it seems to have a bit of play on it as it never had this prob before if anyone could help that would be great ps it goes into gear fine its just when moving the stick thanks
auto gear stick help please
Have a look here, particularly at Nifty Nev's post with the diagram - the bushes are in a darker, highlighted colour:
http://www.toyotasurf.asn.au/forum/v...ght=9038511003
What an excellent link, with pics, diagrams and parts numbers...no excuse not to do it now.
Thanks a lot yorta.
Just like the original post in the link mine went almost overnight rather than gradually.
The post is about a 2nd Gen but I assume it's the same set up for the 3rd Gen? The pics of the shifter and linkage look the same as mine.
How easy is it to replace the bushes with the big bolt..?
Having gazed at it like an idiot, to me it would seem that undoing the linkage underneath (have to to replace the bushes) and then remove the trim around the gear shift, loosen the bolts etc holding it in and lift out enough to access the bolt..? Or have I mis understood or not got the right idea..?
(Mine wobbles and this has made me want to fix it!!Last edited by Jameswallace; 20 December 2014, 21:16.
