does anyone know how to lift the front suspension by adjusting the torsion bar cheers
Hi & might as well post a hello first but anyhow.......Yup just measure the front distance, figure out how much you want to wind them up. Jack up the front to take pressure off the bars, mark the bolts, and about 12 turns will give you about 1" of lift if i remember right. Take the jack out (after letting it down), drive round a bit to settle then measure again and repeat as required..... Job done
Search funtion at the top is good too.
RobThe sh$t gets deeper ...but still swimming
