Hi,
It's that time to change the factory suspension on the Surf, but the only problem is I am getting very confused with terms such as body lifts, suspension lifts and the like.
I want to change the suspension of the Surf, i have ruled out buying genuine Toyota parts (the wreckers that stock them other here, have old 2nd hand ones from Japan), but I am unsure as to what aftermarket shocks i can use. The original shocks have and electirc like connector while most aftermarket shocks i see have a round hole type connector.
What aftermarket shocks can i fit to the Surf?
What size springs should i fit
Also i would like the Surf to be raised abit but not too high. I want it to be high so that no mods are needed (ie only fitting shocks and springs) Is this possible?
Hope this hasn't been too confusing to read...
